Activity Forums Blackmagic Design Poor quality capture on Extreme
  • Poor quality capture on Extreme
    Posted by Burt Holland on September 1, 2005 at 6:11 pm
    I am having trouble getting a good capture through my Decklink Extreme card. Basically it looks like a phase or termination type issue, where there is a shift and my luminance drops significantly. Rather than try to explain it all here I made a webpage with some screen captures showing my problem.
    I will warn ahead that it is fairly long, but if anyone has time to check it out and thinks they might be able to help I would greatly appreciate it.
    The link is
    https://www.encyclomedia.net/BM/decklink_issue.htm
    I’ll apologize for my lack of web authoring ability – I’m an editor not a web designer.
    Jason Levy replied 21 years ago 3 Members · 4 Replies
  • Yves De muyter
    September 1, 2005 at 6:29 pm
    I would throw away the reference thingy and lock the deck on the input, not on the reference… Our UVW-1800P nicely locks on the input, it can even lock on a VHS composite signal, better than any other VTR I’ve ever seen.
    -Yves
  • Burt Holland
    September 1, 2005 at 6:44 pm
    Doesn’t your UVW-1800 complain then that it doesn’t have a reference?
  • Yves De muyter
    September 2, 2005 at 5:17 am
    Yes, but besides complaining, it does work.
    -Yves
  • Jason Levy
    September 5, 2005 at 2:50 am
    You are running your Y (luma) signal through the reference first… is that supposed to work? why don’t you try using the y out of the decklink card for ref in on the deck. Set the y out to output black on capture.. (in your os x system settings decklink pane)
    Just a shot in the dark.. Good luck.
    Jason
