Activity Forums Adobe After Effects Poor Performance with HDV footage
  • Poor Performance with HDV footage
    Posted by Lee Eric on May 1, 2007 at 9:02 pm
    I am using footage shot on a JVC HD110U. It works great in Premiere but when I attempt to work with any of the footage in AE it becomes very sluggish and almost inoperable. Any suggestions or insight?
    Thanks.
    Tim Vaughan replied 19 years, 4 months ago 3 Members · 2 Replies
  • Kevin Camp
    May 1, 2007 at 9:45 pm
    i think you’ll want to use an intermedate codec that doesn’t use interframe compression to go between ae and pp… i don’t think hdv can be set to not use interframe compression.
    you’d hate to use another lossy codec, so i would try to use lossless animation, but it will eat up a lot more disk space. an image sequence would work well too. if you had to conserve disk space, photo jpeg might be a decent lossy codec to look at.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Tim Vaughan
    May 1, 2007 at 10:11 pm
    Generally, I convert the HDV footage to DVCPro HD, same size. It costs a bit more in real estate, but is much faster than HDV. You can pick up a great converter called MPEG Streamclip by Squared 5 that does some great conversion if you do not have the cards on your computer. Hope this helps…
    Tim
    Tim
