Activity Forums Adobe After Effects Poor JPEG Quality inside of 3D Effect
  • Poor JPEG Quality inside of 3D Effect
    Posted by Mikhael Kiesler on February 16, 2009 at 9:26 pm
    I’m still tinkering with a project where I need to animate a book. I’ve gotten the Illustrator files from the animator of all the book pages. From those, I built a 21 page book in After Effects – which came out pretty nicely.
    My problem is this: in the intro sequence the book kind of flies into the camera and then floats down to where it needs to be before opening. When you see the book as it flies up, the image is very noisy and pixelated – not at all like the EPS files used to make them. Even worse, when the book opens to the dedication page, the text is so blurred/smudged as to be illegible.
    The EPS files of the pages are 8.5×11 in. Since I’m working in NTSC standard, though, my frame is set to 720×480 px. Is the large size discrepancy causing this issue?
    Mikhael Kiesler replied 17 years, 6 months ago 26,778 Members · 1 Reply
  • Mikhael Kiesler
    February 16, 2009 at 10:09 pm
    I’m not entirely sure what the Continuously Rasterize option is – but I will definitely investigate…
    Alright. After a bit of reading, I’ve enabled the switch – I’ll have to play with it to know how it will turn out.
    Thanks again, Dave. :]
