Activity Forums Adobe InDesign Poor image quality
  • Poor image quality
    Posted by Ruud Van gerven on January 4, 2013 at 10:09 am
    Helly everyone!
    I’m having some troubles getting my images to look nice and crisp. I’ve allready searched the net for solutions but that didn’t solve my problem. In Photoshop i’ve drawn a basic pie chart and placed it in my indesign file. The Display Performance is set to High Quality Display and Overprint Preview is enabled. The Fitting is correct. I’ve added a screenshot to this post with 2 piecharts, one is .png and the other .psd but that didn’t change anything aswell. The original file is 300 DPI high quality.
    As u can see, the edges and the numbers are not smooth.
    Help would be greatly appreciated!
    Grtz Ruud
    Dwayne Smith replied 13 years, 7 months ago 3 Members · 2 Replies
  • Chiali Tsai
    January 7, 2013 at 4:32 pm
    maybe you should do it in illustrator, they have this graph tool is very easy to use.
    else if you stick in photoshop, make sure you have enough pixels.
  • Dwayne Smith
    January 9, 2013 at 11:26 am
    G’day
    Different tools are used for different purposes. Photoshop is great for ‘photos’ and similar types of images — it is not great for graphic type images (for the reasons you have discovered).
    Basically it comes down to the difference between pixel-based images and vector images. Vectors keep their crispness under virtually any circumstance — whereas pixel-based images are subject to the restraints of ‘resolution’.
    For this type of image you could use Illustrator. But there’s also no really good reason not to build it directly in InDesign.
    d.
