Activity Forums Adobe Encore DVD Poor DVD Quailty
  • Poor DVD Quailty
    Posted by Kevin Herrin on August 9, 2006 at 5:50 pm
    I have a concert video about 1 hour long that I did in Premiere 2 and then encoded in Encore that the video looks very strob like. The picture quality is good, but when there is motion I am seeing a lot of stobbing. Is it better to export Mpeg 2 from Premiere or do I let Encore do it? Also what is the difference between AVI and DV.AVI?
    Thanks for the help
    Kevin
    Abel Rey replied 16 years, 2 months ago 3 Members · 5 Replies
  • Neil Wilkes
    August 9, 2006 at 6:17 pm
    Let Encore handle it unless you know exactly how to encode an MPEG-2 file for DVD-Video.
    AVI is just an acronym for Audio Video Interleave, and there are as many variations on this as grains of sand on a beach.
    What I would recommend is exporting from Premiere Pro as a DV AVI – around 13Gb/hour – and letting Encore handle the MPEG-2 encoding in Automatic mode.
    Your description of “Strobing” could well be – if it is what I think it is – a problem caused by a mismatched field order.
    What was the source of your file? Was it captured from DV cam?
    What settings did you use to export from Premiere?
  • Kevin Herrin
    August 9, 2006 at 7:25 pm
    I captured DV transfered from from Beta and DVCPro. My export was DV.AVI, I didn’t change any of the settings. Do I need to set the field order on the source video, similar to AE? Any suggestions on the AVI settings.
    Kevin
  • Neil Wilkes
    August 10, 2006 at 10:18 am
    AVI settings.
    You have 2 choices here.
    DV AVI or uncompressed.
    I would use DV AVI personally, and let Encore handle transcoding to MPEG-2 automatically.
    Are you running Premiere Pro 1.5.1 or 2.0? (This is actually quite important)
  • Kevin Herrin
    August 10, 2006 at 2:46 pm
    I’m using 2.0, I did figure out what the problem was. For some reason the settings were set to 24p. I changed it back to 29.97 and all was right. Thanks for the assistance.
    Kevin
  • Abel Rey
    May 31, 2010 at 12:52 pm
    kevin
    i know its been a long time seens you post this messege but somehow i could read it. i am breaking my head with a problem that at last i found someone who had experience it too and i mean about the bad quality when moving the motion. i saw you solved the problem by adjusting the settings from 24p to 29.99p but i cant find where is it. can you help me please?
