Activity › Forums › DaVinci Resolve › Polygon window animation
  • Polygon window animation
    Posted by Andrew Shtern on August 22, 2011 at 1:25 pm
    Hi all.
    Is it possiple to animate shape of the PPW? I’ve tried all ways of animation (marks, track and adjust keyframes), but it seems that i can animate only the position/rotation/scale, but not the shape of the PPW. Every change of any point’s position became global. So, it’s not possible, or there is some way?
    Andrew Shtern
    Editor/Colorist
    The Coffeepost @Kiev, UA
    Sascha Haber replied 15 years, 1 month ago 2 Members · 1 Reply
  • Sascha Haber
    August 23, 2011 at 1:19 pm
    All four windows store shape keys just fine.
    They also store on off keys, which might be tricky sometimes when turning it on in the middle and wondering why its not active in the beginning.
    But try as the manual says :
    Switch to your node animation with All,Color,PTZR
    go to a frame you like, start dynamic
    go to another frame, start dynamic again (why not add keyframe to existing dynamic ??? anyway…)
    do some shape changes on the corner points
    press play, it should move.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
