Activity Forums Maxon Cinema 4D Polygon selection parented to a null object
  • Polygon selection parented to a null object
    Posted by Alec Iselin on August 5, 2013 at 7:27 pm
    is it possible to parent the position of a polygon selection to a null object? I’ve tried the poly node in expresso, and didn’t get anywhere with that.
    Adam Trachtenberg replied 13 years, 1 month ago 2 Members · 3 Replies
  • Adam Trachtenberg
    August 5, 2013 at 9:46 pm
    What are you trying to do? Move the null along with the polygons, or move the polygons with the null? Or something else?
  • Alec Iselin
    August 6, 2013 at 4:53 am
    I wanted to move the polygons with the null, but Someone on the C4d Cafe gave me the answer. You just place a cluster object inside the mesh, use a vertex map for the selected vertices, load that map into the cluster object, and then designate the null as the cluster objects target… in case anyone else is wondering.
    Thanks though.
  • Adam Trachtenberg
    August 6, 2013 at 2:45 pm
    Yep, that’s what I was going to suggest. Or you could use a joint weighted to the vertices in question.
