Activity Forums Maxon Cinema 4D Polygon reduction – falloff ?
  • Brian Jones
    June 15, 2018 at 4:20 pm
    Have you seen this on C4DCafe?
    https://www.c4dcafe.com/ipb/forums/topic/96686-falloff-control-a-bevel-deformer-on-fracture-obj/ (down the thread a bit, ‘deformer_falloff.c4d’)
    The thread there states this won’t work on the bevel deformer and I suspect not on the reduction deformer either because of the way it works internally. Neither of those got a falloff built-in when those were added to the other deformers, I’d have to guess there is a good reason for that. (but just guessing)
  • Steve Bentley
    June 15, 2018 at 9:20 pm
    Shouldn’t geometry detail concentration be the determining factor for reducing polys and not where the polys are on the object?
