Activity Forums Maxon Cinema 4D polygon independent colouring
  • polygon independent colouring
    Posted by Hans Castrop on June 23, 2022 at 10:45 am
    I’ve got a low poly object and want to color one half red, the other half blue. Selecting polygons and adding material with this colour gives a jagged edge. I would like a perfect straight line. is there a way to do this, so it is polygon independent? Thanks
    Andy Kiernan replied 4 years, 3 months ago 2 Members · 1 Reply
  • Andy Kiernan
    June 23, 2022 at 12:47 pm
    that would depend on your geometry. You cant colour half a polygon this way. Better off using a gradient applied across your geometry in the shader. If it has to be poly selections, then the geometry must align to where you want the colours to change
