Activity Forums Maxon Cinema 4D Polygon Hair R13
  • Polygon Hair R13
    Posted by Ashley Goodall on January 25, 2012 at 12:39 am
    I have a project were I am using “Polygon Hair” Material in R13.
    (Balloons on string) When I render the material is black. If I open in R12 works fine.????? is there something new to click in R13
    David Biederbeck replied 14 years, 7 months ago 2 Members · 3 Replies
  • David Biederbeck
    January 25, 2012 at 1:08 am
    Try adding a “render” tag to the object (under rt click, hair tags, render).
    I had this problem with thinking particles linked to a tracer object last night.
  • Ashley Goodall
    January 25, 2012 at 1:24 am
    Thanks for that. But no joy : ( Still not working.
    Here are some frame grabs. This is driving me nuts.
  • David Biederbeck
    January 25, 2012 at 3:26 am
    Not too necessary for that few pieces to simplify the geometry to hair material. Sweep it!
    If you are looking for it to be organic and flowy, you can create a connected tracer object to 2 point selections, and convert current state of the object. Then break it down into desired subdivisions.
    Simon Holmedal teaches that trick here- https://vimeo.com/19092137
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
