Activity Forums Maxon Cinema 4D Polygon from shadow
  • Polygon from shadow
    Posted by Hawkowski on March 28, 2006 at 4:10 pm
    Dear Cinema 4D Gurus,
    Is it possible to (auto) create a polygon from shadow ei. can we convert a selected shadow into a closed polygon?
    A simple example; we can illuminate a cube object in such a way that it’s shadow takes a diamond shape. Can we convert this diamond shaped shadow into a polygon with four edges? If the answer is “Yes”, then can we use the same technique to create arbitrarily complex shaped polygons from any shadow?
    Regards
    Roberto Hawkowski
    Greg Serafin replied 20 years, 5 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    March 29, 2006 at 12:50 am
    No can do.
  • Greg Serafin
    March 29, 2006 at 2:50 am
    Not automatic, but will do the trick:
    Bake your shadows (in top view) and use the resulting image with Vectorizer for SPlines, or Relief to create a mesh (may have to delete the “non-shadows” polys)
    IQ
