Activity Forums Maxon Cinema 4D Pole Vector Issue
  • Pole Vector Issue
    Posted by Spencer Noble on July 8, 2015 at 7:08 pm
    Hi. I apologize for the basic question, but its keeping me from progressing on a project I have.
    I’m trying to get an IK chain to bend a certain way so I thought I’d set up a Pole Vector using a Null below the chain to influence it. But when I try to drag the Null into the ‘Object’ line to make the pole vector the ‘object’ option is grayed out.
    I don’t know how to change this simple, annoying issue.
    I’m used to maya so I’m sure this is really basic, sorry.
    Adam Trachtenberg replied 11 years, 2 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    July 8, 2015 at 10:34 pm
    Do you per chance have the IK method set to 3D?
  • Spencer Noble
    July 9, 2015 at 2:29 pm
    I tried switching it from 2D to 3D and back again with no change, but I managed to set an object as the pole vector by creating an IK tag for my joint and manually setting a goal instead of selecting all the joints and creating an IK chain.
    Thanks for your help though.
    A lot of your answers in these threads have helped me in the past
    Cheers
  • Adam Trachtenberg
    July 9, 2015 at 3:26 pm
    Glad you worked it out. The only way I could recreate your problem was to set the IK method to 3D, so I’m not sure what happened.
