Activity Forums Adobe After Effects Polar coordinates
  • Polar coordinates
    Posted by Timothy Chew on April 12, 2010 at 9:55 pm
    Hi there,
    I’m attempting to recreate this effect in AE with footage-
    https://www.flickr.com/photos/snarfo/119870372/
    I rotate the footage 180 degrees and increase the interpolation, but unlike PS, AE bends the footage “inwards” on itself, rather than “outwards” to achieve the globe effect. I apologize for the non-technical language :).
    Would greatly appreciate any suggestions or solutions, it could very well be something totally simple!
    Planet Shaped Amazing Circle (Tutorial)
    Steve Roberts replied 16 years, 5 months ago 3 Members · 4 Replies
  • Steve Roberts
    April 12, 2010 at 10:23 pm
    Have you tried turning the image upside down first? Try applying distort>transform first, to rotate it 180 degrees.
  • Timothy Chew
    April 12, 2010 at 10:54 pm
    Steve,
    Thanks for the reply. Yeah, that is where I am stumped. Rotating the image 180 degrees in PS works but not in AE.
    -Tim
  • Darby Edelen
    April 12, 2010 at 11:32 pm
    [Timothy Chew] “Thanks for the reply. Yeah, that is where I am stumped. Rotating the image 180 degrees in PS works but not in AE.”
    That’s because in PS you rasterize the image as rotated 180° and then apply the Polar Coordinates function. After Effects will apply the Polar Coordinates effect and then apply the Transforms/Rotation. It’s an order of operations problem.
    You either need to pre-compose your layer, rotate it 180° in the pre-comp and apply Polar Coordinates to the pre-comp.
    Or, as Steve suggested, apply a Distort > Transform effect above the Polar Coordinates effect and set the rotation to 180° in the Transform effect properties.
    Either of these will work.
    Darby Edelen
  • Steve Roberts
    April 13, 2010 at 1:14 am
    “Above” … “first” … same thing, but redundancy is good.
    Timothy! Read my post again! 🙂
    Effect>distort>transform is soooo useful. For example, if you want to flop a layer but still be able to scale it up or down normally, use the aforementioned effect to scale x to -100, Y to 100. Then you can scale normally with abandon.
