Activity › Forums › Adobe After Effects › Polar coordinates – PS and AE discrepancy
  • Polar coordinates – PS and AE discrepancy
    Posted by Jamie Bradshaw on June 23, 2009 at 6:42 pm
    Hi all.
    I’ve got a problem that I hope someone here could help out with.
    Basically I’ve noticed that there is a discrepancy between the After Effects and Photoshop with regards to the Polar Coordinates effect.
    For example, I have a 1280 x 640 piece of footage in AE. If I apply the Polar Coordinates effect to it (Rect to Polar, 100% Interpolation) then the image gets mapped to a circle. However, doing the equivalent thing in PS maps the image to an elipse.
    I need the AE version of Polar Coordinates to behave the same way as the PS version. Does anyone know how to do this? Or even why the two behave differently?
    Jamie
    JimJam•Graphics
    https://www.jimjamgraphics.com/
    Darby Edelen replied 17 years, 3 months ago 4 Members · 5 Replies
  • Michael Szalapski
    June 23, 2009 at 6:30 pm
    I’m not by my AE or Photoshop machines at the moment. However, a real quick though. You can export your stuff from AE to be used in Photoshop and apply the effect that way, if need be.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Jamie Bradshaw
    June 23, 2009 at 6:46 pm
    Thanks Michael.
    I think I should have said that due to other requirements of the project, I really need to solve this in After Effects.
    J
    JimJam•Graphics
  • Jamie Bradshaw
    June 23, 2009 at 8:08 pm
    Hi Dave.
    I’m using square pixels. I’m pretty sure that the pixel aspect ratio wont make a difference though.
    JimJam•Graphics
  • Chris Forrester
    June 24, 2009 at 2:13 am
    Could not resist looking at this post 😛 I did some tests to observe the differences.
    In the case of AE polar coordinates will always make a circle, the circles diameter seems to be the height of the footage. I observed this by also adding a transform effect before the polar coordinates effect and adjusting first the scale of the height and after the width. The only time it changed the shape was when I adjust the height, internally I am guessing AE is making the image taller in pixels and then polar coordinates picks up that value.
    Based on this to solve your problem (as has been suggested) it has to be a post transform-scale to correct it. You would work out the % difference in your image sizes 1280/640 = 2 , scale the width after polar coordinates by this amount 100%* 2 = 200% . I write it here as a formula as you might some day have other sized footage and I am sure this would allow you to add a favorite effect with a small script to automatically scale the image after depending on your original image sizes. (I think the logic here of the simple formula would work if the height was taller than the width…not tested it though). I rather do the transform in the effect panel because it frees my normal timeline transform for animation and I can add scripts to the effect with out effecting any animation I might have already.
    Hope this helps and thank you for pointing out the odd quirkiness..next I am off to see how we can make PS act like AE polar-coordinates. As to why they behave differently we can only assume PS stretches the image to the height and width of the canvas just because it felt more artistic, what people might want?? I have not used polar coordinate graphics before in my work so I am not sure what the standard look is seems a circle would make more sense..maybe someone else can chime into there uses I am thinking more used in 3d sphereical mapping but used same manner in AE?
    Regards
    Chris Forrester
    demoreel https://chrisforrester.tv
  • Darby Edelen
    June 25, 2009 at 8:58 pm
    [chris forrester] “You would work out the % difference in your image sizes 1280/640 = 2 , scale the width after polar coordinates by this amount 100%* 2 = 200%”
    This is similar to the approach I would’ve taken to figure out what was going on, and very near what I expected.
    My one suggestion is that instead of scaling the layer up 200% horizontally you should scale the layer 200% vertically with a Distort > Transform effect first, then apply polar coordinates and then use the scale property (or another Transform effect) to scale the layer down 50% vertically. The results are much cleaner.
    Darby Edelen
