Activity › Forums › Adobe After Effects › Points not following light properly
Posted by Max Hurd on November 16, 2015 at 11:20 amRelatively new to AE and I’m hoping someone can tell me why I have a gap between my points and my light. View the gfycat here.
My order of operations: Track motion, Target Null, Convert Null to Light using Null Swapper, apply Plexus 2.
Cassius Marques replied 10 years, 10 months ago 2 Members · 6 Replies -
Cassius Marques
November 16, 2015 at 5:27 pmis the solid you’re applying plexus the same size of your composition? Is plexus set to use the comp camera?
Cassius Marques
http://www.zapfilmes.com -
Max Hurd
November 16, 2015 at 5:48 pm -
Cassius Marques
November 16, 2015 at 6:46 pmIt should be matched right, unless you changed any world coordinates in the plexus settings. Or your grey solid is not 720p.
Try to create a default 35mm camera.
can you upload the project? It would be easier. You may want to remove the footage to make it small.
Cassius Marques
Max Hurd
November 16, 2015 at 8:07 pmOK, I will try that. In the meantime, here is the project file with no footage:
Max Hurd
November 16, 2015 at 8:22 pm -
Cassius Marques
November 17, 2015 at 11:03 amSorry for the delay, had to go home.
well I think it is something I hadn’t considered. A bug.
Since it opens fine for me. So I advise you to check for updates.
Cassius Marques
