Activity › Forums › Apple Final Cut Pro Legacy › pocket drive for FCP editing?
Posted by Raju Bhai on July 13, 2005 at 5:55 pmI have a PowerBook G4, 1.67, 2 gig RAM, 17 inch. I want to know if there is a small extrenal drive that will be fast enough (i guess 7200 RPM) to edit on. Portablity is important and so is superior functionality, speed and reliablity. Let me know what drives are available that would work.
thanks!Paul Nevison replied 21 years, 1 month ago 3 Members · 4 Replies -
Bryce Whiteside
July 13, 2005 at 6:28 pmThere is the G-DRIVE mini found here G-TECH G-DRIVE-mini Ultra Portable FireWire and USB Storage Solutions
Unfortunately their 7200RPM drives are showing out of stock, but perhaps other VAR’s like videoguys.com might have some.Another option might be WiebeTech Micro Storage Solutions – FireWire and USB Hard Drives and putting your own drive in one of their portable enclosures.
HTH,
BryceDon’t worry Mr. B. I have a cunning plan…
PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
Final Cut Pro HD
DVD Studio Pro 3
Motion -
Paul Nevison
July 13, 2005 at 8:03 pmive been using the ‘on the go’ 60gig 7200rpm pocket drive from other world computing for the last year for powerbook editing and it’s awesome. bus powered, light, fast and see-through funky!
i got it for a great price…check out the site
https://eshop.macsales.com/shop/firewire/
system 1 G5DP 2.0 / 2.0G RAM / OS 10.3.8 / QT 6.5.2 / FCP HD 4.5 / CineWave 4.7 / Cinewave RT Pro/ Pro Digital Plus & Pro Analogue BOB
Raju Bhai
July 13, 2005 at 11:46 pmhi, I just checked out the site! THey only have 2 models that are 7200 RPM, right? One of them is a combo drive and it’s only $4 more than the one that has only Firewire. It costs $270. Also, it doesn’t say, but do u know if it uses the new faster firwire connection or the slower one?
Also, u have been using this for over a year to edit FCP on, right? I will be doing the same thing, not using it as a storage drive but as a workhorse editing drive. You have found it to be very reliable and rugged to take with u on the road? -
Paul Nevison
July 18, 2005 at 7:50 pmhey there
when i purchased, the firewire only version was cheaper than the combo so i went with it.
it’s worked flawlessly for me – on the road – it’s rugged enough – just dont drop it from a height or spill coffee on it (standard drive care)!!!
my drive has two FW400 ports – i dont think they have a FW800 version.
