Activity Forums Adobe After Effects PNGIO Error when rendering
  • PNGIO Error when rendering
    Posted by Corrie Parks on June 1, 2019 at 3:33 pm
    I’m trying to render a PNG sequence and receive the following error.
    AEGP Plugin PNGIO Support: PNGIO library error: profile “After Effects ICC Profile”: 0h: PCS illuminant is not d50 (5027::12)
    I can render other formats and sequences from the comp without problem.
    Render settings are PNG sequence, RGB + alpha, Millions of Colors+ No Compression
    If I try to render a PNG without an alpha I get this error:
    My source files are PSDs. I had a couple PNGs in the original comp but changed them to PSD when troubleshooting with no change in the error.
    AE 16.1.1 (Build 4)
    Windows 10Pro
    Thanks for any insight into this problem.
    Corrie Parks replied 7 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
