Activity Forums Maxon Cinema 4D PNG transparency on an invisible plane
  • PNG transparency on an invisible plane
    Posted by Jon Simpson on July 14, 2014 at 8:14 pm
    Im trying to figure out how to fit a .png to a plane and have the transparency work on the .png and the plane be invisible. Not having any luck…
    Adam Trachtenberg replied 12 years, 2 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    July 14, 2014 at 9:13 pm
    Create a material and load your png into the alpha channel. Then place the material on the plane.
  • Jon Simpson
    July 14, 2014 at 10:46 pm
    Excellent, thanks! Now the only issue I have is that it is casting a shadow fine on the background but it should also be reflecting. I have the texture set on both sides and I turned up the reflectivity on the background to make sure it wasn’t showing. The background is reflecting all of the other elements just fine.
  • Adam Trachtenberg
    July 14, 2014 at 11:30 pm
    My guess is that you don’t have any light shining on the back side of the PNG plane, so the background is just reflecting darkness.
