Activity Forums VEGAS Pro PNG to MOV
  • PNG to MOV
    Posted by Frenchie29 on July 23, 2007 at 9:13 pm
    How can I tranfer .png files to .mov the way it should be??
    I imported all the files, I can see them on the time line but it’s really frame by frame, like 2 seconds on each frames. How can I make this a movie file???
    Frenchie29 replied 19 years, 1 month ago 2 Members · 2 Replies
  • Edward Troxel
    July 23, 2007 at 9:31 pm
    Is this supposed to be ONE frame per PNG? And are they numbered (i.e. png0001, png0002, etc…) If yes, you may want to do a File – Open, select the first one, and then check the box that says “Image Sequence”.
    Once on the timeline, File – Render As will let you go to any format you wish.
    Edward Troxel
    JETDV Scripts
  • Frenchie29
    July 24, 2007 at 6:10 pm
    Awesome thanks alot
