Activity Forums Boris FX Particle Illusion PNG is rendering poorly Bad TV lines-AVI also
  • PNG is rendering poorly Bad TV lines-AVI also
    Posted by Randal Radabaugh on March 11, 2011 at 7:19 pm
    I have used PI3 many times. have rendered using PNG alpha with BG removed.
    never had an issue with any images- used in Sony and AE with
    good results for couple of years. just a few weeks ago it was fine.
    All of a sudden, any PNG seq. is rendering out very poorly
    I get faded lines,bars almost like a bad TV effect.
    I also got PI plug in for AE- if I use it in AE it looks fine,
    but using PI3 alone is more versatile than plug in so I use it to
    edit,change emitters-
    have looked thru many many past posts and cant find the answer.
    Some help please…
    have tried every codec and avi files do it too.
    okay this is getting weird.
    I have rendered a single frame (same frame 3x) get a different hue on each, and on 2 I get full view render, and 1 I get the PI renderer. all PNG save alpha no Black BG and no BG at all.??
    Alan Lorence replied 15 years, 5 months ago 2 Members · 3 Replies
  • Alan Lorence
    March 11, 2011 at 11:17 pm
    Does JPG work?
    Try using “run with software rendering” in the Start menu. If that works, then it’s a video driver issue.
    Alan.
    http://www.wondertouch.com
  • Randal Radabaugh
    March 11, 2011 at 11:56 pm
    Thank you for replying.
    okay jpg looks fine
    did some things -am not sure what, but it has improved slightly,
    instead of contrast lines, it is more pixelated.
    Should not be any comp problems- I just got it back from PC shop 2 weeks ago.
    Start menu? run with software rendering. where is this? << see dont show warning for software rendering in preferences. but no use software rendering. I reset to defaults- seems to have helped.still not High quality but much better than it was.is not Bad TV now 🙂 still would like to know where this use software rendering is. have looked thru app menus,open GL,pref, proj settings etc. thanks Randal R
  • Alan Lorence
    March 14, 2011 at 7:23 pm
    In the Start menu.
    Start – All Programs – particleIllusion 3.0 – troubleshooting
    Alan.
