Activity Forums Apple Motion PNG
  • Posted by Matt King on March 28, 2008 at 6:39 pm
    I just made a bunch of pngs from photoshop using the save for the web function to keep the alpha channel. For some crazy reason, Motion can only see the first and last ones I made. All the others are not even showing up in the file browser. Final cut sees them just fine. Photoshop sees them…finder sees them….motion doesn’t.
    Am I missing something very elementary here?
    Motion 3
    PS CS 2
    Thanks for any guidance folks.
    -Matt K
    Matt King replied 18 years, 5 months ago 1 Member · 1 Reply
  • Matt King
    March 28, 2008 at 6:52 pm
    Anyway. There must be something to sitting down and writing out your thoughts after spending waaayy too much time trying to figure out a solution to a simple problem. At least that must be the way it is for me…because about 2 minutes after I got fed up and posted a plea for help…I tried something different than the other things I had been trying before.
    I used the import function instead of grabbing straight from the file browser. I don’t generally use the import because once a long time ago Motion didn’t like the way I was trying to import a file and I decided that that wasn’t the way I should go and I put import out of my mind..until about 2 minutes ago…and this time it works.
    Even though I didn’t give anyone here a enough time to respond. Thanks for being there to let me put my thoughts out and figure it out anyway…..back to work now.
    -Matt K
