Activity Forums Sony Cameras PMW – feeding picture into an external SD video monitor
  • PMW – feeding picture into an external SD video monitor
    Posted by Lawrence Robbin on October 7, 2008 at 3:49 pm
    Anyone had any trouble feeding picture into an external SD video monitor using the BNC connection?
    I’m not having any luck. I turned off the i-link in the menu. Any suggestions. Thanks
    Lawrence Robbin replied 17 years, 11 months ago 3 Members · 4 Replies
  • Stephen May
    October 7, 2008 at 5:35 pm
    For that job I did in a ballroom recording the governor and senator, etc. they wanted I-mag as well, and at first I assumed the BNC was the spigot but I was in a hurry, and the I-mag was a little last minute, and I didn’t get it either (possibly it’s only SDI) – so I decided to go with the break-outs, and your choices are Composite (AV breakout on side below handle – yellow RCA) or you can go component, RGB breakout.
    I had to assign in the menu, but it worked fine. You will need to decide about crop or letterbox since the SD monitor is 4:3.
    -Stephen
    Stephen May
    Keystone Media Productions
    Freelance Videographer
  • Lawrence Robbin
    October 8, 2008 at 5:09 pm
    Thanks, Stephen, I will try your suggestion. Sounds like you didn’t have any luck getting composite/bnc/SD from the PMW also.
    LR
  • David Issko
    October 8, 2008 at 8:56 pm
    I am using the (SD) BNC monitor output from my EX3 for my 8mm telecine transfers. I have the output set to 4×3 centre cut. It worked first time and has worked every time since and I have transferred lots of films to DVD since I took delivery of my camera some weeks ago. No special settings other than centre cut.
    David Issko
  • Lawrence Robbin
    October 9, 2008 at 4:36 pm
    David… To follow up on what you wrote:”I have the output set to 4×3 centre cut”. Where is that in the menu? I would think it would in the Menu section called VIDEO SET. But I don’t see “4×3 centre cut”. I have just found on the bottom of page 118 of the manual there’s a table called Limitations of Outputs. Later today, I’ll see if that’s helpful…. btw why do you go to 8mm telecine?
    thx for the help
    LR
