Activity Forums Apple Final Cut Pro Legacy PMW-EX30 HD-SDI Workflow
  • PMW-EX30 HD-SDI Workflow
    Posted by Joao Velho on August 14, 2010 at 12:11 am
    Does anyone know if it is possible to capture XDCAM EX material from the PMW-EX30 HD-SDI output as PRORES files using the HD-SDI input of a Kona or Decklink card? In this case, does this work well?
    Thanks for any help!
    Joao
    Michael Gissing replied 16 years, 1 month ago 2 Members · 1 Reply
  • Michael Gissing
    August 14, 2010 at 12:15 am
    You can capture to ProRes codec from an HD SDI input. The source codec is irrelevant as the camera/ deck is converting the signal to an uncompressed SDI signal.
