Activity › Forums › Sony Cameras › PMW-EX1 Stutter on Movement
  • PMW-EX1 Stutter on Movement
    Posted by Rajnesh Domalpalli on July 20, 2010 at 11:51 am
    Hello,
    I recently bought a PMW-EX1 and I’ve been happy with it, expect for one problem. When I record a Moving Object OR if the Camera Moves, I find that the image goes in and out of focus. The problem seems to be independent of what setting I use.
    Could you recommend something that I can do?
    Thanks in advance for your help.
    Regards,
    Rajnesh
    Phoniox Glade replied 14 years ago 4 Members · 5 Replies
  • Craig Seeman
    July 20, 2010 at 2:07 pm
    Without specific settings or details on how you are monitoring it’s hard to say. Also do you understand the general recommended limits when shooting 24p and panning? These are not at all specific to EX. 24p has temporal motion limits when panning. That’s why 60p or 60i are often used for sports.
  • Don Greening
    July 20, 2010 at 5:54 pm
    [Rajnesh Domalpalli] “The problem seems to be independent of what setting I use.”
    Maybe you should be a little more specific about what settings you’re referring to. For example, are you shooting with auto focus?
    – Don
  • Rajnesh Domalpalli
    July 31, 2010 at 10:04 am
    Don and Craig, Thanks so much for replying.
    I used the following settings on my PMW-EX1 (given at Bottom).
    and also uploaded a clip 46.2Meg 1280×720 QuickTime movie here. The Video was originally shot on 1920×1080 with the settings given below, then imported into FCP and Exported to the smaller format for upload.
    In the Video you see the Camera Pan along with the Subject.
    The trouble I’m having is with the Subject intermittently going in and out of focus/ becoming blurry.
    Why is this and what can I do to alleviate the problem?
    CAMERA BUTTONS
    Iris : Manual
    Macro: Off
    Focus: Manual
    Zoom: Servo
    AF/MF Right: Pushed to MF
    ND Filter: Off
    Gain: Low
    Full Auto Light is Green
    White Balance: PRST
    CAMERA SET
    Gain Setup: Low
    Shutter->Mode: Speed ShutterSpeed:1/96
    EX Slow Shutter->Setting: Off
    Shot Transition->Trans Speed: 5 Time/Speed: Speed Trans Curve: SoftStop StartTimer: Off RecLink:Off
    MF Assist: On
    Color Bar Type: Multi
    Flicker Reduce->Mode: Auto Frequencey:50Hz
    Zoom Speed-> High:70 Low: 30 Remote: 50
    Interval Rec-> Setting: Off Interval Time: 1sec Num of Frames: 1
    Frame Rec-> Setting: Off Num of Frames: 1
    S&Q Motion-> Setting: Off Frame Rate: 30
    Rec Review: 3 Sec
    Fader-> Fade In: Off Fade In Type: Black Fade In Time 2 sec Fade Out: Off Fade Out Type: Black
    TLCS-> Level: 0 Mode: Standard Speed: +50 AGC Limit: 12db AGC Point: F2.8
    Shockless White: 2
    White Switch: ATW
    ATW Speed : 3
    Wide Conversion: Off
    Steady Shot: On
    VIDEO SET
    YpBpPr/ SDI Out Select : HD
    YPbPr/ SDI Out Display: On
    24P System : 60i
    Thanks in advance.
    Regards,
    Rajnesh
  • Craig Seeman
    July 31, 2010 at 2:31 pm
    I don’t think you understand some of the basics.
    What frame rate?
    [Rajnesh Domalpalli] “Shutter->Mode: Speed ShutterSpeed:1/96”
    That’s one way to increase stutter. You want more motion blur not less. Shutter speed relative to frame rate impacts motion blur.
    You really need some basic understanding of Cinematography. We probably can’t give all that info here since you seem to be at newest of newbie level. There’s lots of good training DVDs out there.
    You need to understand basic concepts like frame rates, shutter speed, temporal resolution. You need to understand the impact those choices have on the image and when and why one would change them. Then there’s how you, the operator, handle motion when panning relative to the frame rate.
  • Phoniox Glade
    September 20, 2012 at 11:41 am
    Did you ever work out how to get around this as I’m suffering from a similar issue and I know it’s how I’m using the EX1R but don’t know how to fix it
