Activity › Forums › Sony Cameras › PMW-350 side Video Out Port?
  • PMW-350 side Video Out Port?
    Posted by Michael Moser on August 3, 2010 at 9:32 pm
    If I don’t have the SD option on a PMW-350 what is the output of the side video out port. I’m told it is one channel of component; switchable to SD/SDI is this correct? It’s obviously not the HD/SDI out.
    Michael Moser
    Michael Moser replied 16 years, 1 month ago 2 Members · 2 Replies
  • Ian Cook
    August 4, 2010 at 1:44 pm
    Hi Michael,
    The Video Out port gives you either an analog composite signal or the luminance (Y) channel of the HD signal (selectable in the Operational menu under Input and Output–>Output and i.LINK). It is intended for monitoring purposes and will output a down converted SD signal regardless of whether the SD option is installed.
    Ian
  • Michael Moser
    August 4, 2010 at 2:23 pm
    Thanks. That’s what I thought.
    What we discovered was that the color phase of the SD composite signal has no relationship with the color phase of the HD/SDI signal and not knowing that required a re-do of a base-line camera set up… It was a gotcha we should have anticipated, but unfortunate. I have always used the HD/SDI out for monitoring, but now I understand how it can be used as a second monitor, but not a “test out.” as in the older cameras in that form-factor.
    Mike
