Activity Forums Sony Cameras Pmw 200 firmware upgrade
  • Pmw 200 firmware upgrade
    Posted by Paul Parker on March 28, 2014 at 6:02 pm
    Hi guys I need help I did a firmware update on my pmw200 v1.32 all was going ok till phase 3 when a warning came
    Up version error followed the instructions which says just switch off and repeat from step 1 …the problem is the camera won’t switch off took the supply out and the sxs card and when I powered on again without the sxs card installed the camera went straight to phase 2 upgrade and 3 and error now the camera is dead all I have is the recording bulb on the front on and that’s it tried prime support BUT the answer was since I called at 4.45 that we have to call you Monday!!! Is there a way to physically reset the camera fro the outside? Is there a reset button on some way of doing this?
    THANKS
    Mark Thompson replied 12 years, 3 months ago 3 Members · 3 Replies
  • Ian Cook
    March 28, 2014 at 7:06 pm
    I am sorry to hear that. No, unfortunately there is no way to force it to upgrade on boot-up without special software.
  • Paul Parker
    March 28, 2014 at 7:34 pm
    Thanks Ian seems like I have to send it to them I suppose
  • Mark Thompson
    June 13, 2014 at 12:21 am
    Hi I assume it all worked out in the end? Was the firmware buggy or was it a procedural error?
    thanks
    mark
