Activity › Forums › Apple OS X › PM quicksilver 2002 second drive location
  • PM quicksilver 2002 second drive location
    Posted by Craig Alan on October 8, 2006 at 5:07 pm
    Ok my problems below (please help 10/4/06) turned out to be a wounded second internal hard drive. Once disconnected from the ribbon cable, the system drive then worked fine. So I now need to install another second drive. I notice that since the second drive was taken out of the sled, the system drive runs 10 degrees cooler. I would prefer to keep it this way.
    In a quicksilver 2002 PM, can I install a second drive in drive position 2? If so, what ribbon should I buy so it will reach from drive position 3 to drive position 2? Or would it be better to buy a third party pci card giving me another bus? https://www.sonnettech.com/product/tempo_ata133.html for example.
    Unfortunately for me, I borrowed my external HD on which I had backed up the second drive to use at work. Therefore I did not have a back up of it. It
    Craig Alan replied 19 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
