Activity Forums Apple Final Cut Pro Legacy PluralEyes Multiclips Need render in FCP 7?
  • PluralEyes Multiclips Need render in FCP 7?
    Posted by Kiran Goldman on July 6, 2010 at 3:27 am
    I am editing a two-camera interview shot with the EX3 and the Canon 5D/7D. I transcoded all the 5D/7D footage to match the EX3 settings, and then used PluralEyes to sync the footage and create multiclips. I have my sequence settings set to 1920 by 1080 HDTV 1080i (16:9), frame rate is 23.98, and the Compressor is XDCAM EX 1080p24 (35MB/s VBR).
    The settings for the multiclips are frame rate 23.98, XDCAM EX 1080p24 (35MB/s VBR).
    Do you know why there is always a green render bar over the multiclips when I try to edit them into the timeline? Is there a way around them? Is this a problem that is caused by using PluralEyes.
    Jeremy Garchow replied 15 years, 12 months ago 6 Members · 8 Replies
  • 8 Replies
  • Michael Gissing
    July 6, 2010 at 6:53 am
    Is the render for the picture or audio? Is the audio 48khz 16 or 24 bit?
  • Shane Ross
    July 6, 2010 at 6:58 am
    A green render bar is normal. You will always have some tender bar over multiclips. There is no way to have NO render. Green render bar should play back fine.
    Shane
  • Jeremy Garchow
    July 6, 2010 at 2:11 pm
    Agreed. You have to remember, a multiclip is playing back multiple streams, hence the green bar.
  • Kiran Goldman
    July 6, 2010 at 2:57 pm
    If I create the multiclips withing FCP, there is no render bar, but if I use PluralEyes to create the multiclips, then there is a green render bar when I try to edit into the sequence. Any idea why this is only happening with the multiclips from PluralEyes and not from the multiclips created within FCP?
  • Jeremy Garchow
    July 6, 2010 at 3:11 pm
    [Kiran Goldman] “Any idea why this is only happening with the multiclips from PluralEyes and not from the multiclips created within FCP?”
    No, but the multiclips that I create in FCP always have a render bar. It is never the dark grey ‘full’ bar.
    Perhaps contact SIngular Software and see what they say.
    Jeremy
  • Michael Craven
    July 6, 2010 at 5:00 pm
    Once you’ve completed your edit, collapse the multiclip and the green render bar should disappear.
  • Daniel Steiner
    September 29, 2010 at 6:46 pm
    I’m getting a RED render bar over my multiclip created within pluraleyes. All of my footage specs match the timeline specs (XDCAM EX 720p60). Any ideas?
  • Jeremy Garchow
    September 29, 2010 at 11:30 pm
    In your sequence, go to the “rt” button in the top left corner. Is the “Multiclip Playback” option checked?
    Any filters on your master clips?
    I sa wjsut yesterday or before, there’s a new update the Plural Eyes that did something with multiclips. If these don’t work, maybe try the update?
