Activity Forums Adobe After Effects Pluraleyes extending clips, becoming un-synced on XML import to Premiere Pro
  • Pluraleyes extending clips, becoming un-synced on XML import to Premiere Pro
    Posted by Paul Leavitt on January 30, 2017 at 2:51 pm
    Hey all! I’ve been using Pluraleyes for a year or so now and absolutely love it. But recently it’s started adding black video to the ends of every clip, and it’s not synced in Premiere. If I sync in the pluraleyes app (as opposed to the plugin for Premiere), it appears to be synced and it doesn’t extend the clips, but as soon as I import into premiere, the same thing happens: extends all clips, becomes out of sync. I’m running 4.1.3 and the latest CC.
    Here’s a screenshot of what’s happening:
    Kevin Carlson replied 9 years, 3 months ago 2 Members · 1 Reply
  • Kevin Carlson
    February 14, 2017 at 3:06 pm
    Maybe you are having “Immaturity Problems”? Just kidding…
    Most of my problems I have not figured out yet are showing up after I bring in the xml.
    My current problem is the audio recorder tracks are empty–kinda the whole point of using PE. I have looked at where the tracks start from timecode in the stand alone PE and that gets me close, but it’s still a big problem.
    You could try downgrading to prior version–they did a major over-haul to create v4. I think I might do the same thing here.
    Please write if you figure it out!
