Activity › Forums › Adobe Premiere Pro › Pluraleyes extending clips, becoming un-synced on XML import to Premiere Pro
  • Pluraleyes extending clips, becoming un-synced on XML import to Premiere Pro
    Posted by Paul Leavitt on January 30, 2017 at 10:40 pm
    Hey all! I’ve been using Pluraleyes for a year or so now and absolutely love it. But recently it’s started adding black video to the ends of every clip, and it’s not synced in Premiere. If I sync in the pluraleyes app (as opposed to the plugin for Premiere), it appears to be synced and it doesn’t extend the clips, but as soon as I import into premiere, the same thing happens: extends all clips, becomes out of sync. I’m running 4.1.3 and the latest CC.
    Here’s a screenshot of what’s happening:
    Mike Powis replied 7 years, 10 months ago 4 Members · 6 Replies
  • Duke Sweden
    January 30, 2017 at 10:42 pm
    I used to use Plural eyes as well, but now it’s easier than ever to sync video and audio files in Premiere Pro. Just choose your video, and your audio, then right click and choose “merge files”. That’s it. WIth Plural Eyes it always created like 4 different clips and things got really messy.
    Anyway, you might be light years ahead of me and need the features of Plural Eyes. Otherwise, try my suggestion.
  • Paul Leavitt
    February 1, 2017 at 7:54 pm
    How I wish it were that simple! Merging clips only works (to my understanding) if you have 1 video track with audio, and a separate audio track (plus, timecode is often needed). Since I’m trying to sync multiple video tracks, plus audio, I either have to sync each clip individually (using the Synchronize function), or just do it manually. Would significantly slow my process down. :/
  • Duke Sweden
    February 1, 2017 at 8:25 pm
    Got ya. Hence the last sentence of my previous comment 😉
  • Paul Leavitt
    February 1, 2017 at 9:11 pm
    Ok! After chatting with Red Giant support, it turns out that the problem is some where in the XML round tripping, but we figured out a solution! Before syncing, change the sequences setting to match the frame rate of the clip with the highest FR in the sequence. So for my example I had mostly 23.967, which was what my sequence was, but I had one clip from my backup camera which is 29.97. So I changed my sequences settings to 29.97, synced with pluraleyes, and then changed he resultant sequence back to 23.976. Works like a charm.
  • Pat Depuy
    July 10, 2017 at 7:12 pm
    Paul, thank you for sharing your issue and solution, this helped me out big time as I was experiencing the same problem and digging everywhere to figure out the most efficient workaround. Cheers!
  • Mike Powis
    November 26, 2018 at 4:33 pm
    Paul had an issue and wrote about it online.
    After troubleshooting the issue by contacting the software provider Paul came up with a fix.
    Paul then went back to the thread he started so that anyone experiencing the same issue who came across his thread would know a quick and easy fix to said problem.
    Be like Paul guys..
