Activity Forums Adobe After Effects Pluraleyes 3 error message
  • Pluraleyes 3 error message
    Posted by Jana Birchum on March 21, 2014 at 9:44 pm
    I’m using PluralEyes 3, with Premiere Pro CC, and I keep getting an error message that says
    “The input clip “MVI_0481.MOV” is not linked with audio in the timeline. This sequence cannot be synced.”
    Whe I remove that clip, it moves down one more. It syncs some clips, but not all.
    Is there a workaround? I’ve linked and unlinked the clips to the camera audio track, which they’re linked to already. But I link then unlink them then link them back. No luck.
    Any idea what the issue is?
    Jana B.
    Jesse Garrison replied 11 years, 6 months ago 3 Members · 2 Replies
  • Adam Mcclelland
    May 11, 2014 at 7:16 pm
    Did you ever find a solution to this?
  • Jesse Garrison
    March 12, 2015 at 5:06 pm
    It’s possible that he had no audio in one of the clips to sync to his audio. Make sure you have a audio in the clip that PE is saying is an error.
