Activity Forums Adobe Premiere Pro plural eyes question
  • plural eyes question
    Posted by Jason Brown on June 6, 2014 at 2:26 pm
    I have an issue – I have a 42 minute video that was edited down to a 9 minute cut. I was only given the beginning and end. (no project file).
    I was hoping I could use plural eyes to sync the edit up with the original in various places?
    I’m not using premier, just the stand alone plural eyes product. There is no forum for plural eyes.
    Phillip Todd replied 12 years, 1 month ago 2 Members · 3 Replies
  • Phillip Todd
    August 2, 2014 at 1:39 am
    Should work fine. Did you try it?
    Phillip Todd
    Cinematographer
    http://www.phillip-todd.com
  • Jason Brown
    August 2, 2014 at 2:12 am
    Yes I did, would not work.
  • Phillip Todd
    August 2, 2014 at 3:40 am
    Make sure that all sources have the same frame rate.
    Try to have all sources in their correct chronological order.
    In the menu you will see 2 extra options, which solved a problem for me recently:
    “Allow re-ordering of clips”
    “Try Really Hard”
    Both are worth trying. Helped me the other day.
    Red Giant does says in their help files to try and keep PE projects below 30 minutes.
    -Phillip
    Phillip Todd
    Cinematographer
