Activity Forums Apple Final Cut Pro Legacy Plural Eyes & Audio Mixer
  • Plural Eyes & Audio Mixer
    Posted by Daniel Schloss on November 15, 2010 at 8:55 am
    I’ve been using plural eyes to sync my clips. When I bring the 3 audio tracks from Seq 1 into Seq 2 after using plural eyes, my audio wave forms can be seen but the mixer controls no longer work. The audio can actually be controlled with the sliders in the audio mixer however there is no audio level reading. Is there a setting I’ve failed to activate to show the audio levels on the various tracks of the mixer? They work in the other sequences just not the plural eyes one with the copied audio tracks brought over. Thanks
    Chris Tompkins replied 15 years, 9 months ago 2 Members · 4 Replies
  • Daniel Schloss
    November 15, 2010 at 9:45 am
    One other thing with this audio issue. I read in another thread that my sequence settings should match my clip settings. My sequence shows the Audio Format at 32-bit floating point but my clips are at 24-bit integer, does this matter, could this be the issue, if so how where are they located to reset…if they can.
    Dan Schloss
    info@echomedia.org
  • Chris Tompkins
    November 15, 2010 at 12:16 pm
    Check ur sequence settings (CMD 0) there is a check box to show levels I believe. Also, zooming out and back in can change the view sometimes.
    Chris Tompkins
    Video Atlanta LLC
  • Daniel Schloss
    November 15, 2010 at 7:06 pm
    Thanks Chris, yeah I think things are all screwed up with this project. Any adjusting of the audio causes it to have to be rendered again and again. Normally I can hear the audio with the render warning beep but not now. I can only hear it if I render or scub the time line. Arrrrrr
    Dan Schloss
    info@echomedia.org
  • Chris Tompkins
    November 16, 2010 at 12:13 am
    What is the format of these files? You should convert them to 48K Aif’s and u’ll lose most ofg your problems.
    Run em thru Soundtrack
    Chris Tompkins
    Video Atlanta LLC
