Activity Forums Adobe Premiere Pro Plugins/Effects/Transitions
  • Plugins/Effects/Transitions
    Posted by Danielle Warren on July 31, 2014 at 3:04 pm
    Hi everyone! I have recently started learning Premiere as I see more and more people switching from FCP7 to that (and I’m not an Avid fan). So far I love it. It is so similar to FCP which makes the learning process so much easier.
    One thing I’ve come across early though is the effects are pretty lacking, especially the transitions. Can anyone recommend some good effects/transitions packages for Premiere Pro? I had a lot for FCP7 that I used often, so I miss them, although I’m not sure if those translate over.
    Thanks for the help!
    Aleksey Tarasov replied 12 years ago 5 Members · 6 Replies
  • Steve Brame
    July 31, 2014 at 3:22 pm
    FilmImpact.net. Great set of transitions.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Danielle Warren
    July 31, 2014 at 3:24 pm
    Cheers Steve! I will take a look.
  • Jerry Wise
    if you used Nattress then you are SOL. same thing for CGM. if you loved the page-turn effect in FCP…sorry…SOL.
  • Danielle Warren
    July 31, 2014 at 3:26 pm
    Hey Jerry, thanks for the positive comments lol! I used Nattress and Sapphire a lot. Not sure what CGM is. Sounds like a lot of what I used I am now SOL. So what are the alternatives for people who use Premiere Pro?
  • Daniel Waldron
    August 1, 2014 at 7:56 pm
    Check out FX Factory. They’ve got what appears to be hundreds of plugins and transition packs.
  • Aleksey Tarasov
    August 16, 2014 at 5:26 pm
    Check out these clip-based effects, especially Transquare transitions
