Activity Forums Adobe After Effects Plugin/Effect Animation Presets missing in CS5?
  • Plugin/Effect Animation Presets missing in CS5?
    Posted by Jack Cook on June 4, 2010 at 7:02 pm
    Recently upgraded to CS5 and when applying an effect to a layer, where there were animation presets in older versions of AE, they are no longer. For example, in CS4, Fractal Noise had several “presets” displayed in a drop-down menu at the top of the Effect Controls panel (Blocks, Cinders, etc.), but it seems that in CS5, they are no longer available? This goes for third-party plugins as well, such as Particular. The presets exist on the hard drive, and can be accessed from Bridge, however this is a time-suck and can’t be easily previewed. Anyone having the same problem, or some UI setting I’m missing?
    Todd Kopriva replied 13 years, 5 months ago 7 Members · 9 Replies
  • 9 Replies
  • Brian Charles
    June 4, 2010 at 7:52 pm
    In CS5 the default setting for the Effects Control panel is not to show presets.
    Select it from the panel drop down and your’e good-to-go.
  • Jack Cook
    June 4, 2010 at 8:05 pm
    THANK YOU!!! Seems weird that Adobe would turn this off by default, but I am happy to know that the option to turn it off is there, if needed.
  • Michael Szalapski
    June 4, 2010 at 8:47 pm
    I prefer it off. I rarely, if ever, use presets so I just want the effects themselves to come up when I’m searching.
    Adobe has had people request it both ways, I guess my side won 😛
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Todd Kopriva
    June 5, 2010 at 1:39 am
    BTW, this—like every single other change, no matter how small—is listed here:
    https://help.adobe.com/en_US/aftereffects/cs/using/WS8269FE00-C552-478b-9204-69AF1B4F3432a.html
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Eric Kirk
    September 24, 2011 at 2:43 pm
    Boy, this was a big help. I can’t count how many times I’ve run in to this and just accepted that the presets were no longer available!
    Eric
    Eric D. Kirk
    http://www.kirkproductions.com
  • Stoney El-abd
    February 7, 2012 at 2:23 pm
    Yup, me too, just accepted that they were gone. Really dumb of me considering that the gillion presets I have slow my startup time by 3-5 minutes and I’m always dumping presets from the ‘net into the presets folder in my sidebar.
  • Eric Kirk
    February 7, 2012 at 2:44 pm
    Well, I sure hope you read the solution in the thread. Someone posted a picture of how to fix it. Wow, I wrote that a long time ago.
    Eric
    Eric D. Kirk
  • Stephan Nilson
    April 17, 2013 at 3:51 pm
    OK. I’m having an issue that goes beyond just checking “Show Animated Presets.” I have the option selected, but when I expand the Animated Preset drop down box there are no options. The Animated Presets are in the Effects and Preset window, but that’s not giving me what I want when I want it. Here are two images to show what I’m referring to.
    Thanks.
    Stephan
  • Todd Kopriva
    April 17, 2013 at 6:53 pm
    Stephan, have you saved any animation presets involving this effect? If not, what do you expect to see there?
    After Effects team blog
