Activity › Forums › Apple Final Cut Pro Legacy › Plugin to remove video noise?
  • Plugin to remove video noise?
    Posted by Robb Stan on January 18, 2006 at 5:41 pm
    Does anyone know of a plug-in or plug-ins for FCP that can reduce or eliminate video noise and enhance the detail in a clip that is from an in-store video surveillance camera?
    Martin Banks replied 17 years, 7 months ago 4 Members · 3 Replies
  • Rick Dolishny
    January 18, 2006 at 6:54 pm
    What you are describing sounds mutually exclusive but I know what you’re after. 🙂
    A common Inferno and AE trick for noise reduction is to blur just the blue channel.
    There is also an app Virtual Dub for PC that has an interesting filter I’ve seen before and after shots of but not used myself.
    In FCP there is a free ‘too much too soon’ filter called noise reduction but I’ve tried it on a couple of clips and not noticed a difference, but that may be user error on my part.
    – Rick
    Rick Dolishny
    rdolishny@hotmail.com
    http://www.dolish.com
  • Glenn Chan
    January 18, 2006 at 10:42 pm
    Virtualdub on the PC side has a bunch of noise removal plug-ins available.
    MSU denoiser
    2- Now this workflow is pretty terrible, but Noise Ninja (Photoshop plug-in) does an even better job.
    You have to export an image sequence of PROGRESSIVE frames to photoshop. And then batch actions in Photoshop (set things up first).
    Noise Ninja is reasonably cheap and does a really good job.
    3- Grain Surgery for After Effects does something similar to Noise Ninja. Supposedly it’s slightly inferior to Noise Ninja (this is from what digital still photography sites seem to say).
    I think Grain Surgery is also available for FCP.
    4- Graeme Nattress (Nattress.com) also sells some noise reduction filters, although I have never tried them.
  • Martin Banks
    February 25, 2009 at 1:30 pm
    I am looking to do the exact same thing on some CCTV footage an found your post when I did a search.
    Did you have any luck with any of the plugins/filters? I would love to know how it went and if you have any suggestions.
    In my case the footage has some artifacts at 100% size, however I need to scale up certain sections for a court case and I have been trying my best to remove some digital noise that appears every few frames as a honeycomb type pattern, as well a smothing some of the pixelated edges.
    I tried the Too Much Too Soon plugins however I also found that I could get it to give me any visable/decent results, but again, that may just be me using it incorrectly.
    Martin
