Activity Forums VEGAS Pro Plugin Problem
  • Plugin Problem
    Posted by Andrei Stoicescu on December 24, 2013 at 7:49 pm
    Hi! So I have this problem, I’ve installed the New Blue plugin from Boris on my computer BUT when I did it I only had ONE WINDOWS USER. Then I created the second user (because I share my computer with my bro) but when I launched Vegas 12, the new presets were not there. So, in other words, this plugin does not work on the last user created and I can’t figure out why. Maybe the folder in the Program Files is not shared among all the users? Sorry if it doesn’t make any sense, hope you understand and thanks in advance if you come up with something helpful.
    Steve Rhoden replied 12 years, 9 months ago 3 Members · 2 Replies
  • John Rofrano
    December 24, 2013 at 8:21 pm
    New Blue and Boris are two different companies so I’m not sure which plug-in you installed. Sometimes when you install software it will ask if you want to install it for a single user or everyone on the computer. If you install it for a single user you won’t see it under any other account. You should also know that the nature of plug-ins is to save presets on a per user basis in the user’s Registry, AppData folder or Documents folder. So it’s not surprising that a new account on your system will not see any of this.
    I suggest you give your bro the new account unless he needs the same plug-ins. BTW, many End User License Agreements licence software to the user who purchased it. This would further limit using this software in a multi-user environment even if it is the same computer since it’s not the user who purchased the software.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    December 24, 2013 at 9:19 pm
    First of all, that doesnt make sense, those are two different
    companies and im not clear as to which specific plugin you
    are referring to.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
