Activity › Forums › Adobe After Effects › Plugin controls not fitting into the window of a panel unless stretched all the way.
  • Plugin controls not fitting into the window of a panel unless stretched all the way.
    Posted by Ace Volkov on September 4, 2017 at 4:57 am
    Duik is an animation plugin donationware. I’ve tried installing the latest versions of it several times and it creates an odd misalignment seen below
    some of the controls are outside of the confines of the plugin panel hiddeon away at the corner like so:
    while they should look like
    This problem occurred since installation I’ve opened the program to this state of affairs. Please let me know if there’s a better way to formulate this bug
    Thank you!
    Ace Volkov replied 9 years ago 1 Member · 0 Replies
  • 0 Replies
