Activity Forums Apple Final Cut Pro Legacy Plugin compatibility
  • Dave Johnson
    February 23, 2010 at 4:56 pm
    It’s doubtful anyone can offer a blanket answer that will apply to all FCP plugins … version compatibility typically varies from plugin to plugin so the question might be best to direct to the developers of the particular plugins you have in mind (or the associated system requirements documents).
  • Iain Mackinnon
    February 24, 2010 at 12:09 pm
    ok, the only ones that don’t come up are my bcc effects, the ones i really wanted. Damn! can anyone explain this?
    Iain MacKinnon
    Video Editor
    Splash Productions Music Complex
    http://www.splashproductionscomplex.com
    I used to spend my time wondering, now it’s used up rendering
  • David Johnson
    February 24, 2010 at 12:25 pm
    Unlike many plugins, BorisFX plugins typically require installation (as opposed to just copying the individual plugin files from folder to folder) since they tend to rely on other components placed on your computer during the install process.
  • Matt Mullen
    February 27, 2010 at 10:27 pm
    What version of BCC are you trying to use?
