Activity Forums Adobe After Effects Plugging Matte holes quickly – unavailable in CS5
  • Plugging Matte holes quickly – unavailable in CS5
    Posted by Immanuel Morales on May 14, 2011 at 4:54 pm
    When Adobe removed the vector paint plugin from AE a handful of animators complained that they couldn’t create a specific type of stylized animations, but i have a completely different problem with this. I loved painting directly in comps for the purpose of plugging Matte holes manually. I used a layer solid with vector paint – this was a perfect alpha matte for the holes/specs. This workflow was a LIFESAVER in many comping situations. I’ve been trying to find an alternative in CS5 but so far I’m hitting a wall.. any ideas?
    Dead the Fed
    Rob Dahl replied 15 years, 4 months ago 2 Members · 1 Reply
  • Rob Dahl
    May 14, 2011 at 7:06 pm
    While I may not be understanding your question completely, I have been using CC Vector Blur to eliminate various imperfections in layers.
    I just create a solid. Mask the area I need to fix and apply CC Vector Blur. I apply the blur amount (20), leave vector map at none, and change the property to alpha. Map Softness at 42 if I want the alpha to blur.
    Then I add the layer as an alpha (inverted)layer or use Set Matte if multiple mattes are needed at different levels.
    Rob Dahl
    Transparent Alchemy
    Boulder City, NV 89005
    http://www.transparentalchemy.com
