Activity Forums Apple Final Cut Pro Legacy Plug ins not showing up.
  • Plug ins not showing up.
    Posted by Scott Davis on June 25, 2005 at 11:18 pm
    Hi, my plug ins are not showing up.
    They are: Natress set 1, Digital Heaven Grid and Guides, and some other ones.
    So far I’ve tried:
    1-Putting them in Library/Application Support/FCP System Support/Plug Ins
    2-Taking them out of the folder they where in
    3-No I don’t have any Automatic Duck Plug Ins
    4-Repaired permissions
    5-Rebooted
    One shows up, Digital Heaven’s “guides”
    I’m running G5/FCP 5/10.4.1/QT 7.1
    Ivan George replied 21 years, 2 months ago 4 Members · 6 Replies
  • Graeme Nattress
    June 26, 2005 at 12:15 am
    Check file permissions in the finder, using “get info”. Make sure they’re all “read and write”.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Tim Vaughan
    June 26, 2005 at 12:22 pm
    I had a similar problem. My resolution was to go to applications–>Final Cut Pro–> Right click, Show Package Contents–>Contents–>Plugins. I had to delete any extra plugins within the plugins folder and reinstall. Once I did that, everything magically worked again. Hope this helps!
    Tim
  • Scott Davis
    June 27, 2005 at 2:08 pm
    Thanks Graeme and Tim, checked both your suggestions and all is well. The only plug in that is working is labeled as a “Final Cut Pro Pluging File” the ones not working are “unix executable files” or .txt files.
  • Graeme Nattress
    June 27, 2005 at 4:45 pm
    Looks like they need re-installing from the original downloads or media then.
    Graeme
  • Scott Davis
    June 27, 2005 at 10:23 pm
    Oh, makes sense. What I did was back up my plug ins to a flash drive when I bought a new G5 and then I just copied them over to the FCP folder. I’ll try this tonight when I get home.
  • Ivan George
    July 1, 2005 at 3:10 am
    I had the same problem. Fixed it by moving all the plugins to a whole new directory. I’m not at work now but if anyone still needs to just reply to this thread. Apple should of a made a note to correct this problem from FCP 4 to 5.
