Activity › Forums › RE:Vision Effects › Plug-In will not import into AE
  • Plug-In will not import into AE
    Posted by Bobby Holbrook ii on July 26, 2006 at 9:37 pm
    The plugin is at “www.revisionfx.com/rstwixordownloads.htm” It is a test I am trying todo for a slo-mo spot. This Plug-in suppositly will create a frame or morphe to insert between interlaced frames for 30 fps of 60 fps slo-mo so you do not have the blur or jumping that occurs when not using a high speed camera. I looking to get a nice flid slo-mo shot of a object falling with out that object flickering, blurring or juming from One frame to another. I will be shooting with the Varicam @ 60 fps. Any help or Ideas would be awesome.
    Thanks Bobby
    Peter Litwinowicz replied 20 years, 2 months ago 2 Members · 1 Reply
  • Peter Litwinowicz
    July 26, 2006 at 10:32 pm
    Bobby,
    Not sure what you mean by “will not let me import into AE.”
    You don’t import the plugin into AE, you put the plugin files (those ending in .plugin on Mac and .aex on Windows) into AE’s plugin folder.
    Nor does this plugin give you a different “import” option within AE.
    After you put the Twixtor plugin into the plugins menu, and restart AE, the plugin then shows up in the Effect menu (under the RE:Vision Plug-ins submenu).
    You put some footage into a comp, then apply Twixtor (using the menu item Effect->RE:Vision Plug-ins->Twixtor 4.5.
    You are going to want to set the input settings of Twixtor to have an input frame rate of 29.97 and the appropriate field order (probably Lower Field First). Then you can simply set the speed to whatever you like (for a 4x slowmo, set the speed to 25%). Of course, if you are extending the footage you’ll need to read this: https://www.revisionfx.com/auxdocs/ExtendDuration.htm
    Please read the manual that is put on your disk with the plugins upon installation. It will explain quite a few non-obvious things! Then, when you are done with that, you can go to our tutorials page for more help ( https://www.revisionfx.com/auxdocs/ExtendDuration.htm )
    Pete Litwinowicz
