Activity Forums Apple Final Cut Pro Legacy Plug-in to remove lines going up and down screen?
  • Plug-in to remove lines going up and down screen?
    Posted by Alex Townley on October 25, 2013 at 2:37 am
    Hi guys,
    I was wondering if anyone could give me any tips on how I can fix this footage recorded in a nightclub. There appear to be lines going up and down the screen throughout probably due to a lighting issue. I have tried flicker filter, de-interlace and shift fields filter without any luck..does anyone have any suggestions or is it unfixable?
    N.B. The lines arent quite as visible as before due to video compression but can still be seen particularly on bottom left side.
    Alex
    nightclub_test
    Alex Townley replied 12 years, 10 months ago 5 Members · 5 Replies
  • Shane Ross
    October 25, 2013 at 5:15 am
    Looks like the lighting in the club. I only see it on his shirt, and it’s most likely some sort of spinning globe with light…normal.
    Shane
    Little Frog Post
  • Rainer Wirth
    October 25, 2013 at 12:00 pm
    It looks all fine to me,
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Mark Suszko
    October 25, 2013 at 2:01 pm
    Back up a minute and tell us all about the settings used to shoot this and to edit it.
  • Tom Matthies
    October 25, 2013 at 5:51 pm
    It could be consumer-level LED lighting? It’s notorious for causing all kinds of problems with video cameras.
    E=MC2+/-2db
  • Alex Townley
    October 26, 2013 at 9:13 pm
    Apologies..I am going to upload a longer clip now which hopefully highlights the problem better. The video was shot on a Canon 7D – 1920×1080 (H264) which I then converted to Apple Pro-res LT.
    Thank you for the responses so far!
    nightclub_test2
