Activity › Forums › Adobe Premiere Pro › Plug in to mix PAL footage with NTSC
  • Plug in to mix PAL footage with NTSC
    Posted by David Dicanio on November 14, 2005 at 11:40 pm
    I have some footage shot on a pal dvcam tape and I would like to mix it in with some mini dv ntsc footage on Premiere 1.0 timeline. Rather than taking it to a conversion house, is there softward/ plug in that will allow me to mix the PAL footage on the timeline with NTSC stuff? Without loosing any quality too? Thanks.
    Tim Kurkoski replied 20 years, 10 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    November 15, 2005 at 12:27 am
    You don’t need a plug-in to put NTSC and PAL on the same timeline. What you’re facing here is the simple fact that the PAL footage will need to be converted. Premiere’s not going to do a great job of it, so you’re going to want to convert it before putting it in the timeline. Canopus Procoder is what I usually hear recommended (but I have need of it myself), but other folks may have other suggestions.
