Activity Forums Apple Final Cut Pro Legacy Plug in error in 7.03, forgot how to diagnose!
  • Plug in error in 7.03, forgot how to diagnose!
    Posted by Jiggy Gaton on July 2, 2011 at 11:03 am
    My mind is so warped over FCPX that when a client brought in his laptop with this FCP error, I can’t remember how to troubleshoot. I looked in root/Library/Application Support/Final Cut Pro System Support/Plugins but those are not causing the error. This install has a boatload of plugs, so they must be somewhere else. Client says he used the defaults for all plug installs. Perhaps it’s something else? Thx!
    Phoenix Studios Nepal: A small A/V Production House in Kathmandu.
    Rafael Amador replied 15 years, 2 months ago 2 Members · 1 Reply
  • Rafael Amador
    July 2, 2011 at 12:30 pm
    Hi Jiggy,
    In the capture you posted I can see “Loading Effects Multicolor Vignette..”
    That may be the one causing troubles.
    If is a third party plugin may be installed in Applications or somewhere else.
    rafael
    PS: Wit FCX? You are a fearless guy.
    http://www.nagavideo.com
