Activity › Forums › Adobe After Effects › plug in directory
  • plug in directory
    Posted by Stanly Boon on August 9, 2011 at 2:54 pm
    let me see if i understand it . ae checks the plug in directory before starting and whatever workable plugin that happens to be there , it puts in the user interface. that means that i can dellete effects i dont use , and copy effects that i want in to this folder? did i describe this right? is there a good tutorial about installing plugins in ae ?
    Stanly Boon replied 15 years, 1 month ago 2 Members · 3 Replies
  • Barend Onneweer
    August 9, 2011 at 3:52 pm
    Indeed AE checks the plugin folder for plugins.
    Some effects can be directly copied into the plugin folder – but many of them come with an installer – which also installs the license. Some plugins also install additional software outside of the plugin folder that is referenced or used by the plugin. So you can’t always just drag and drop to install. Sometimes it’ll work, often it won’t.
    Raamw3rk – digital storytelling and visual effects
  • Stanly Boon
    August 9, 2011 at 6:14 pm
    what about cycore?
  • Stanly Boon
    August 10, 2011 at 4:45 am
    i am an apprentice at a big studio. the technical man is horrible and wont help me . my ae [ cs5.5 on win7 ] does not have cycore installed but i found a disk containging a 64 bit version of the cycore effects them slef with no istaller. having does effects will really simplifie my life.
