Activity Forums Compression Techniques pls help with ftp compression
  • pls help with ftp compression
    Posted by Zeliha Bozkurt on October 25, 2007 at 12:49 pm
    Hi All
    I work for a post house and we often need to FTP the programmes to the relevant channels.
    Programmes are edited with FCP 5 using DVC PRO-HD 29.97 codec (7.6MBpsec.)
    Programmes average 1 hour and need to be delivered in MOV or WMV format – 150MB max file size and 320×180 min. dimensions.
    What is the best way I can get this exported and delivered as quickly as possible?
    Zee.
    Daniel Low replied 18 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    October 25, 2007 at 7:07 pm
    Without splitting that clip up, I suggest that you go for low bitrate MPEG-4. Your total data rate NEEDS to be under 250Kb/s to be under 150MB total.
