Activity Forums Adobe After Effects Please rescue me and save my …..
  • Please rescue me and save my …..
    Posted by Syed Iqbal on May 28, 2013 at 6:33 pm
    Hi Guys
    I am negotiating with a buyer and the specs sheet he has given to me has some confusing information (because I am not an expert about aspect rations etc).
    In the resolution requirements, he mentions 3 possible output sizes:
    (16:9) 1280×720
    (16:9) 885×498
    (16:9) 321×498
    Well, in After Effects, for example, when I create a new composition and mention 321 in width and 498 in height, I never see aspect ratio as 16:9 next to these settings. I even tried square pixels and some other settings.
    Your help would be very very appreciated.
    Syed
    Ivan Myles replied 13 years, 3 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    May 28, 2013 at 6:44 pm
    I would suggest that your client revisit their deliver specs. Assuming you’re delivering in h264 then it should be said they do not support odd numbers of pixels. Neither of the smaller sizes are 16:9. I would have your client point to the technical reasons for these selections and if you can use letter/pillar boxes to make up for the difference in aspect ratio
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Syed Iqbal
    May 28, 2013 at 6:50 pm
    Hi dear,
    Perhaps I should have mentioned this before that the available formats to choose from are “MPEG & MOV (H.264,DivX,Xvid)/ WMV,SWF,and AVI”
    So do you mean 16:9 aspect ratio for the 2nd and 3rd size is IMPOSSIBLE, no matter whatever settings we choose from After Effects compostion dialog?
    Thanks a million for your quick response.
    Syed
  • Ivan Myles
    May 29, 2013 at 7:02 pm
    Ask the client whether 884 or 886×498 and 316, 318, or 320×498, are acceptable. You can export 316×498 from Adobe Media Encoder with a custom aspect ratio of 14:5 to produce a 16:9 image.
  • Ivan Myles
    May 29, 2013 at 9:23 pm
    The prior comment refers to exports from a 1280×720 sequence, as you had already recommended.
