Activity › Forums › Apple Final Cut Pro Legacy › please please help ASAP– mpegs too large must burn this dvd
  • please please help ASAP– mpegs too large must burn this dvd
    Posted by Celeste on October 26, 2005 at 5:39 pm
    Greetings. this is really a problem please help.
    mac 0s10
    fcp 4.5
    dvd studio pro
    .mov I put into fcp sequence is 4gb
    upon export and attempt to burn dvd
    mpegs and aif files are too large to fit on dvd over 6gb
    please help. any help.
    should i reexport fcp sequence as an mpeg at a different setting?
    i did mpeg 2
    5
    7
    best
    the sequence is two hours.
    pleasehelp.
    Walter Biscardi replied 20 years, 11 months ago 3 Members · 4 Replies
  • Jeff Carpenter
    October 26, 2005 at 5:47 pm
    First, use A.Pack (an application that should be on your machine) to turn those AIFF files into AC3 files. That will save some space.
    Then try doing a 2-pass VBR at:
    4.5 and 6
    See if those two things get you closer. If not, adjust the numbers slightly and try again. It’s all trial-and-error with this kind of stuff.
  • Walter Biscardi
    October 26, 2005 at 6:18 pm
    If you use Compressor, I’m pretty sure that will give you an estimated File Size when you set up an MPEG-2 to be created.
    Walter Biscardi, Jr.
    Now editing “Good Eats” in HD for the Food Network
  • Celeste
    October 26, 2005 at 6:54 pm
    could not use a pack
    chose to do 1 pass at 3.7 or so
    it is being created now
    will the image be visible?
    they are wanting dvds from a offling photo jpeg seq.
    i exported to 720 X 480 .mov
    and re-rendered this in a sequence.
    what should i do if this mpeg does not work?
    should i break up sequence and put on separate dvds?
    please help this is just a very difficult situation. thanks for your assistance.
  • Walter Biscardi
    October 26, 2005 at 7:30 pm
    [celeste] “could not use a pack
    chose to do 1 pass at 3.7 or so”
    Why can’t you use the A. Pack? It comes with DVD Studio Pro 2 and 3 and is highly recommended for DVD’s. If you create .AC3 audio file, it’s usually about 1/4 the size of an AIFF file.
