Activity Forums Adobe Premiere Pro Please Inform an FCP luddite :-)
  • Please Inform an FCP luddite :-)
    Posted by Robert Smith on March 21, 2013 at 7:13 pm
    Ive got an FCP edit that I decided to try out in Prem 6:
    XML transferred ok except all the audio is “rubber banded” to zero db….ie mute.
    I cannot find how to adjust the rubber band setting (just want it put back to unity).
    NB. there are masses of elements in my program and I cant face using the mouse on each clip.
    Robert Smith replied 13 years, 5 months ago 3 Members · 3 Replies
  • Jan Bauters
    March 21, 2013 at 7:28 pm
    I would select the audio and right click, then select adjust audiogain. Then normalize all peaks to … Whatever you want. Hope It works.
  • Tim Kolb
    March 21, 2013 at 10:43 pm
    I think Robert means the levels are actually reduced to zero…not that the audio level is low in the clips themselves. Audio gain won’t help a clip that has its clip volume reduced to zero.
    You might try to select all the clips (you can drag-marquee select in the sequence, or use the CMD-A to select all)…
    …then right-click and select “Remove Effects” from the menu and select “audio effects” and check only “Volume”…
    Does that accomplish what you need?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Robert Smith
    March 22, 2013 at 10:44 am
    Thanks Mr Kolb , for understanding my issue and for taking the trouble to reply.
